Home » Sponsored » Pi Speakers » mid horns
Re: 80Hz horn [message #46108 is a reply to message #46105] Sun, 02 January 2005 19:11 Go to previous messageGo to previous message
That's a bummer - I had hoped your next message would be either you had a model entered and working, or nearly entered and had a question about some aspect. Once you get rolling on this deal, I think it will be easy for you and you'll like it a lot.
Let's start from scratch on the program. It's a pretty simple install; As long as the files are there, they will execute. No entries are required in the Registry or Windows "INI" config files and no special setup is required. So maybe erase the Hornresp files and re-boot your system, reload the program from download and start over again. That will make sure memory and disk files aren't corrupted in some way.
Previous Topic: Midhorn implementation
Next Topic: Tower 2Pi plans
Current Time: Thu Nov 05 23:42:04 CST 2026
