Home » Sponsored » Pi Speakers » compression driver options?
compression driver options? [message #45958] Mon, 06 December 2004 18:46 Go to next message
Are there any compression drivers out there that are signifigantly better than the PSD2002, without having to spend hundreds more? I was thinking something in the range of 100-150 dollars, with superior performance to the 2002. Or do you have to spend a ton more money to get better results? I don't want anything with a diaphram larger than the 2002.
Adam
Re: compression driver options? [message #45959 is a reply to message #45958] Mon, 06 December 2004 19:12 Go to previous messageGo to next message
BMS handsdown
disclaimer is, i'm a dealer
Re: compression driver options? [message #45972 is a reply to message #45959] Wed, 08 December 2004 14:28 Go to previous messageGo to next message
Black is currently offline  Black
Does Wayne sell this as an option on his speakers? Is it a drop in replacement for the 2002? Does it require a different crossover?
Re: compression driver options? [message #45974 is a reply to message #45972] Wed, 08 December 2004 15:41 Go to previous messageGo to next message
I dont believe Wayne has them for sale yet, but you can email me privately if you like. This is not really a dealers message board.
There are drivers such as the 4550 and 4552ND, both drop in replacements for the 2002. The crossover point would certanly not have to be changed, although the attenuation may not be quite enough. Wayne is a crossover expert and can certainly suggest attenuation options for stronger drivers.
Bill
Re: compression driver options? [message #45981 is a reply to message #45974] Thu, 09 December 2004 06:08 Go to previous messageGo to next message
drguayo is currently offline  drguayo
I'm interested in this as well.... would I be able to find a BMS driver that would screw directly onto my PV CH3 horn?
Wayne: your thoughts on xover tweaks if I swapped compression drivers?
thanks
craig.
Re: compression driver options? [message #45984 is a reply to message #45981] Thu, 09 December 2004 16:03 Go to previous messageGo to next message
I haven't checked into the BMS units, so I honestly can't say. Maybe I'll demo a pair sometime after the holidays when I'm finished with the other projects in front of me right now. But I expect they are probably pretty similar to the current Eminence and JBL models, and could probably be used interchangeably.
Re: compression driver options? [message #45986 is a reply to message #45981] Thu, 09 December 2004 20:26 Go to previous messageGo to next message
Craig,
There is a thread on driver which is my favorite model, the 4540ND I try and use this model when ever possible because it has the smoothest sound and has extreamly high extension. This will screw into a CH3 directly. The draw back to this model is that the reccomended crossover point is 1900hz. This driver can be, and is used in systems with a 1600hz crossover point. It needs to be derated in power handling in this case. For home audio and home theater 1600hz is fine. For high power output the 4552ND driver is a better choice and a screw on adaptor would have to be found.
The 4540ND is my choice and I most always have to use an adaptor to convert them from their screw on mount to a flange mount. These drivers will most certainly need more attenuation in your Pi crossover than the 2002 driver. With out an addition 2-4 db of attenuation depending on the horn you will find the sound very harsh and overly bright as a direct drop in. But then you need different attenuation from an Altec, to a JBL, to an Eminence as well.
I just received these in 16ohm no they will seem a little less sensitive. I havnt worked with them yet.
Bill
Re: compression driver options? [message #45987 is a reply to message #45986] Thu, 09 December 2004 20:40 Go to previous messageGo to next message
OK - next question - is there a CH-3 bolt on version by Peavey so I can then go with the 4552ND?
do thread/bolt on adaptors have much effect on SQ?
thanks everyone.
Craig.
ps. anyone looking for a CRT - I just listed mine on Videogon.
Re: compression driver options? [message #45988 is a reply to message #45987] Thu, 09 December 2004 20:53 Go to previous messageGo to next message
Parts Express sells these to help you out for 5 bucks a piece
Bolt on-to-thread Adaptors
Re: compression driver options? [message #45989 is a reply to message #45987] Thu, 09 December 2004 23:59 Go to previous message
The CH-3 is only available with a screw-on mount. But the adapter in this case is not going to hurt anything.
Previous Topic: importing speakers into australia
Next Topic: Questions: Pialign, Alternative S2Pi Tweeter
Current Time: Wed Nov 04 17:12:21 CST 2026
