Home » Sponsored » Pi Speakers » speaker connections
speaker connections [message #45918] Mon, 29 November 2004 18:43 Go to next message
max3 is currently offline  max3
Recieved my pi 2 speakers today. Just want to make sure since I don't know, but I assume the coil on the speaker connetion goes to the tweeter and the one without goes to the woofer. Is that correct?
Re: speaker connections [message #45923 is a reply to message #45918] Tue, 30 November 2004 10:25 Go to previous messageGo to next message
No, just the opposite. Coil goes to the woofer and straight wire to the tweeter.
Re: speaker connections [message #45932 is a reply to message #45923] Tue, 30 November 2004 17:42 Go to previous messageGo to next message
Thanks Wayne,
Is there any literature around that I can read on how these things work?
Re: speaker connections [message #45933 is a reply to message #45932] Tue, 30 November 2004 18:03 Go to previous messageGo to next message
You bet. Tell me what you want to know and I'll try to point you in the right direction. For starters, here is the CTS applications sheet on the tweeter and the Eminence datasheet on the midwoofer.
Re: speaker connections [message #45935 is a reply to message #45933] Tue, 30 November 2004 21:16 Go to previous messageGo to next message
Thanks for the info. It will take me some time to read through and absorb! Do you have any info on how crossovers work?
A few useful documents [message #45937 is a reply to message #45935] Tue, 30 November 2004 22:05 Go to previous messageGo to next message
  • A few useful documents
  • A few more useful documents
  • Re: A few useful documents [message #45939 is a reply to message #45937] Fri, 03 December 2004 00:49 Go to previous message
    Thanks Wayne,
    That is enough to keep me busy through the next millenium! Thanks again.
    Previous Topic: 34" subwoofer
    Next Topic: Three Pi Stage & Professional Plans
    Current Time: Fri Nov 06 07:53:12 CST 2026
