Home » Sponsored » Pi Speakers » Cap Rating for XO?
Cap Rating for XO? [message #45863] Tue, 23 November 2004 18:47 Go to next message
Hi Wayne. When building a passive XO from scratch, what's an appropriate voltage rating for caps? By my calculation, a 200W amp only puts out 40V into 8ohms. This would mean that Solen's lowest rated caps at 250V should be fine, right? No need to use their PPE series of 650V?
Gar.
Re: Cap Rating for XO? [message #45864 is a reply to message #45863] Wed, 24 November 2004 03:08 Go to previous message
Peak voltage is 1.414 times greater than RMS, so always consider that when choosing capacitors. And there are some frequencies where LC peaking can raise voltage across some components higher than the source. A good example is capacitor C2 in the π Speakers two-way crossover. But 250V is plenty for the capacitors in a crossover like this.
See the π Speaker Crossover document. Pages 68-80 show the voltage across each component in a π Speakers two-way crossover. The source voltage is 50Vrms (70Vpeak) and there are graphs for each component showing the voltage across them as a function of frequency.
Previous Topic: Sex amp and the Pi speakers
Next Topic: DeltaLight 2510 for sealed car sub?
Current Time: Wed Oct 21 01:24:50 CDT 2026
