Home » Sponsored » Pi Speakers » What's The Difference Between A Horn And...
Re: What's The Difference Between A Horn And... [message #45707 is a reply to message #45706] Sat, 30 October 2004 09:25 Go to previous messageGo to previous message
The horn and the radiating diaphragm are two separate things. The diaphragm can be made of any material, just like a direct radiating speaker. You'll see paper, plastic, cloth, metal and composites.
Compression horns put more pressure on the radiating diaphragm than it would have without the compression chamber. There is a constriction in area between the diaphragm and the horn throat which causes pressure to be higher than it would be in free air or mounted on a baffle. So for this reason, the radiating membranes on drivers that are designed to be used on horns are often made more rigid than general purpose drivers.
Previous Topic: Studio 2's Finished, check them out.
Next Topic: Pi 8's up and running!
Current Time: Sun Nov 08 03:35:00 CST 2026
