Home » Sponsored » Pi Speakers » I've got two words for you ...
I've got two words for you ... [message #45585] Fri, 15 October 2004 22:44 Go to next message
ACTIVE CROSSOVER
All that B.S. they talk about in audio reviews: transparency, inner resolution, imaging, clarity, presence, and did I say transparency? They really do exist!
I have seen the evil that is passive crossover.
Gar.
Re: I've got two words for you ... [message #45588 is a reply to message #45585] Sat, 16 October 2004 10:37 Go to previous messageGo to next message
Say, what electronic X-over are you using?
Thanks, Russellc
Welcome into the light, my friend. [message #45590 is a reply to message #45585] Sat, 16 October 2004 11:54 Go to previous messageGo to next message
Another advantage, for me at least, is that I always have the crossover for my next speaker already built.
The is the best part ... [message #45592 is a reply to message #45588] Sat, 16 October 2004 18:19 Go to previous messageGo to next message
It's only an old second hand QSD crossover that I got at Replay in Toronto. It's IC based and I've got it bi-amped with my Gainclone. Absolutely not hi-end equipment-wise but still huge improvements.
Re: The is the best part ... [message #45593 is a reply to message #45592] Sat, 16 October 2004 18:59 Go to previous messageGo to next message
Funny you mentioned Replay - I just wrote to George a couple hours ago. When's the last time you saw him?
Re: The is the best part ... [message #45594 is a reply to message #45593] Sat, 16 October 2004 19:47 Go to previous messageGo to next message
Last night when I bought the crossover from him.
Re: The is the best part ... [message #45595 is a reply to message #45594] Sat, 16 October 2004 20:41 Go to previous messageGo to next message
George is a great guy, isn't he? You guys should form a Toronto Audio Club!
Re: The is the best part ... [message #45598 is a reply to message #45592] Sun, 17 October 2004 09:09 Go to previous messageGo to next message
Hello,
So this QSD, is it still being made, and if I may ask, is it a pro sound type that uses xlr or other that rca type cables? I have heard amazing things about the gain clones, and fully intend to explore them at some point in the very near future.
Thanks, Russellc
Re: The is the best part ... [message #45600 is a reply to message #45592] Sun, 17 October 2004 11:05 Go to previous messageGo to next message
Hey Garman; I am doing the same thing; the Audion xover with the two Gainclones on the Altecs. What speakers are you using and where do you cross at?
Re: The is the best part ... [message #45611 is a reply to message #45598] Sun, 17 October 2004 19:53 Go to previous messageGo to previous message
I don't think this unit is still being made. I cracked open the box and it was dated from the factory in 1985. It's singled-ended with options for balanced, and input/outputs are all 1/4 jacks. However, it came with 1/4 to RCA adaptors.
Previous Topic: Prosound electronic crossovers.
Next Topic: Thermionic 8's plans and center suggestions to match
Current Time: Sat Nov 28 19:41:47 CST 2026
