Home » Sponsored » Pi Speakers » Midhorn depth
Midhorn depth [message #45438] Fri, 24 September 2004 14:21 Go to next message
Jeff Aiken is currently offline  Jeff Aiken
Wayne,
In the detail for the midhorn its labeled with the side panels showing a depth of 14.5" and the top and bottom a depth of 11".
Is the 14.5" for the side panels the actual length of that cut and not necessarily depth? And, is the 11" for the top and bottom actual depth of the whole horn at its center and not necessarily the length of that cut?
Thanks,
Jeff
Re: Midhorn depth [message #45440 is a reply to message #45438] Fri, 24 September 2004 15:11 Go to previous messageGo to next message
The drawings show panel cuts, so since they are at an angle, they are the hypotenuse and longer than the axial length of the horn. What might be helpful is to cut out a cardboard horn using the drawings and you'll see what I mean. That's actually how I did the prototypes - I did the drawings, then cut out cardboard pieces and made mockups, and then I took those to the cabinetmaker to build.
We also have midhorn kits that are cut perfectly, and the fit is excellent. That makes assembly a lot easier.
Re: Midhorn depth [message #45441 is a reply to message #45440] Fri, 24 September 2004 23:59 Go to previous messageGo to next message
So, the top and bottom pieces are as follows, right?
4.5"
_____
11" axis ---->| \
Re: Sorry, reposted my ASCII art here for previous post. [message #45442 is a reply to message #45441] Sat, 25 September 2004 00:17 Go to previous messageGo to next message
Don't know html too well.
..................4.5"
................_____
11" axis ---->|.......\
Re: Sorry, reposted my ASCII art here for previous post. [message #45443 is a reply to message #45442] Sat, 25 September 2004 00:26 Go to previous messageGo to next message
You've got it.
The side pieces are 14.5" long and the top pieces are only 11" long. The flare of the side pieces is much wider, and that's why they have to be longer.
  • π Midrange Horn
  • Re: Sorry, reposted my ASCII art here for previous post. [message #45446 is a reply to message #45443] Sat, 25 September 2004 08:30 Go to previous message
    Thanks again, Wayne.
    Previous Topic: Up-grading Theater 4s? Wayne?
    Next Topic: Delta lite crossover comments
    Current Time: Sun Oct 25 04:20:51 CDT 2026
