Home » Sponsored » Pi Speakers » ideal enclosure volume for alpha 10
ideal enclosure volume for alpha 10 [message #45329] Wed, 08 September 2004 11:33 Go to next message
gary b is currently offline  gary b
there are 3 different enclosure designs for the alpha 10 speaker. (2pi, 2pi tower and 8pi).
In the info section of this website, it says that a woofer has an ideal enclosure volume. what is the ideal enclosure volume for the alpha 10 and why are there three different enclosure designs for it?
Also, how do I find get a value for Qd for he Ve=Vad/Qd equation?
thanks!
Re: ideal enclosure volume for alpha 10 [message #45331 is a reply to message #45329] Wed, 08 September 2004 13:14 Go to previous message
The Alpha 10 speaker works well in bass reflex cabinets ranging from approximately 1.0ft3 to 5.5ft3 tuned to 40Hz. It also works well in sealed cabinets of approximately the same size, and in horns of various shapes and back chamber volumes.
PiAlign suggests 1.4ft3 tuned to 37.5Hz, which is at the small end of the possible bass-reflex alignments. For the electro-mechanical parameters, you can substitute 1/Qts = Qd.
Previous Topic: Heresy components and pi speakers ?
Next Topic: Cabinet help
Current Time: Wed Nov 04 01:10:49 CST 2026
