Home » Sponsored » Pi Speakers » adding a JBL 2360 horn to my 4 Pi's
adding a JBL 2360 horn to my 4 Pi's [message #45175] Thu, 12 August 2004 10:21 Go to next message
drguayo is currently offline  drguayo
I have a pair of JBL 2360 horns with PSD3003 drivers. These horns are huge - like 3' long(2 pieces) with an exit size of 2.5'x2.2'. I'm thinking of just mounting them on top of my 4 Pi's and reworking the crossover to be 3 way. I like the midrange throatiness of the PSD3003 and this horn - so 3 way xover at 800 hz and 12 khz is what I was thinking or maybe I should just go 2 way and use the standard Pi crossover.
any suggestions welcome.
take care
craig
Re: adding a JBL 2360 horn to my 4 Pi's [message #45176 is a reply to message #45175] Thu, 12 August 2004 14:05 Go to previous messageGo to next message
That would make an excellent system. You may be able to run as a two-way, but I think you'll probably want to add a super-tweeter. Those PSD3003's have gotten rare and Eminence isn't planning to have another 2" exit driver ready for nine months. So hang on to 'em.
Re: adding a JBL 2360 horn to my 4 Pi's [message #45177 is a reply to message #45176] Thu, 12 August 2004 14:19 Go to previous messageGo to next message
So just get the 800 Hz Pi crossover? Can I use the PSD2002 with my Peavey horn as the super tweeter? and if so what would I xover at?
hey I'm BACK
Re: adding a JBL 2360 horn to my 4 Pi's [message #45178 is a reply to message #45177] Thu, 12 August 2004 14:25 Go to previous messageGo to next message
Not sure if the PSD2002 would have a lot to add if crossed at 12KHz as it runs out of steam by 16KHz. A pair of APT80 crossed at 5KHz might be a better choice.
Re: adding a JBL 2360 horn to my 4 Pi's [message #45179 is a reply to message #45177] Thu, 12 August 2004 14:34 Go to previous messageGo to next message
Personally, I like using a good 1" exit driver with top-octave compensation to compensate for falling power response. That will get you to 18kHz. If you want to use a larger compression driver, you'll need to use a super-tweeter for the top octave. In that case, I'd probably go with something like the JBL 2405.
Re: adding a JBL 2360 horn to my 4 Pi's [message #45180 is a reply to message #45178] Thu, 12 August 2004 14:35 Go to previous message
Agreed, the APTxx tweeters would do nicely.
Previous Topic: Midrange Horn for PA??
Next Topic: My Eminence Kappa 12 just quit on me :-(
Current Time: Mon Nov 02 05:30:31 CST 2026
