Home » Sponsored » Pi Speakers » The eternal quesiton: Tube friendly or not
The eternal quesiton: Tube friendly or not [message #45146] Mon, 02 August 2004 06:19 Go to next message
roland is currently offline  roland
Hi,
Having read all I can find on tube friendly, damping factor etc, I have the following questions:
If a tube amp has sufficiently low out put impedance (and the resulting high damping factor), I could still be all right with just a couple of watts? It seems that the low damping factor in SETs is the real problem and not necessarily the low power output? After all, if the speaker has 100db/1w/m, 2-4 Watts should be enough, yes?
In for example a PSE arrangement where the additional tube is used for lowering output impedance instead of doubling the power could do the trick??? Example: using 2 x 6as7 (one tube envelope) with for arguments sake a 5kohm primary would yield high enough damping factor to allow for higher Zmax on the woofer...????
Sorry if the quesiton is foolish, but I am really curious on this:)
Roland
Re: The eternal quesiton: Tube friendly or not [message #45147 is a reply to message #45146] Mon, 02 August 2004 07:39 Go to previous messageGo to next message
That's right, Roland. If the amplifier's damping factor is high, i.e. output impedance is low, then speaker impedance fluxuations won't affect response so much.
thanks. I like no nonsense answers. (nt) [message #45148 is a reply to message #45147] Mon, 02 August 2004 08:36 Go to previous messageGo to next message
Re: thanks. I like no nonsense answers. (nt) [message #45149 is a reply to message #45148] Mon, 02 August 2004 09:10 Go to previous messageGo to next message
Yury is currently offline  Yury
hello Roland!
you wrote:
1. "If a tube amp has sufficiently low out put impedance "
if!!!! it's not always. it's depend of scheme, solution. we have to reach it first. the same as transistor amplifier.
2. "and not necessarily the low power output" - it's depend of drivers sound pressure. if you'll load any amp to driver 0.08 Pa - high damping factor of your amplifier don't take a big sound. but 0.4 Pa driver be able to makes biiiigggg loud! :) by 1W
a propos, what do we mean about 1W to 4 ohm? U^2/R. ok. U=2V. nice. signal swing have to be about 5V by oscillograph, couse it's mean square value.
sorry my English.
Re: thanks. I like no nonsense answers. (nt) [message #45190 is a reply to message #45149] Sun, 15 August 2004 10:39 Go to previous messageGo to next message
Yury; What is that .08 PA number mean?
Re: thanks. I like no nonsense answers. (nt) [message #45192 is a reply to message #45149] Mon, 16 August 2004 00:13 Go to previous message
Pa - means pascal. unit of sound pressure.
Previous Topic: My Eminence Kappa 12 just quit on me :-(
Next Topic: My New Theatre Three's
Current Time: Sat Oct 24 10:32:30 CDT 2026
