Home » Sponsored » Pi Speakers » alpha 10
alpha 10 [message #45066] Mon, 26 July 2004 18:47 Go to next message
vmps is currently offline  vmps
what is the different between alpha 10 & alpha 10A?
Re: alpha 10 [message #45067 is a reply to message #45066] Tue, 27 July 2004 01:38 Go to previous messageGo to next message
I'm pretty sure the changes are only minor. If I recall, the 'A' version is just a newer revision of the driver, and that no changes in box calculations were needed.
Re: alpha 10 [message #45069 is a reply to message #45066] Tue, 27 July 2004 02:55 Go to previous messageGo to next message
Eminence uses the "A" suffix to designate 8 ohms impedance. Sometimes people omit the suffix, especially on models that are only available in 8 ohms like the Alpha's. Other models are availble in some lines - "B" is 16 ohms, "C" is 4, "CX" is made for coax tweeter mounting and "LF" is tuned low and "HO" is tuned for maximum output.
by the way how about the new 1" compression driver? [message #45072 is a reply to message #45069] Tue, 27 July 2004 03:45 Go to previous messageGo to next message
wayne & adrian,
thanks for the info, another questiob is can the new compression driver be use in the Pi 8?
vmps
Re: by the way how about the new 1" compression driver? [message #45073 is a reply to message #45072] Tue, 27 July 2004 03:52 Go to previous message
I didn't use the ASD1001, and used the PSD2002 instead. If it will work at 1.6kHz, I imagine it's worth a try.
Previous Topic: Bottlehead tube amps/preamps?
Next Topic: re size the opening of the mid horn
Current Time: Mon Nov 02 01:36:05 CST 2026
