Home » Sponsored » Pi Speakers » Qustions regarding midrange horn.
Re: Qustions regarding midrange horn. [message #45022 is a reply to message #45020] Wed, 21 July 2004 05:18 Go to previous messageGo to previous message
For a straight sided horn, you basically set the angle you want for the dispersion pattern. At low frequencies, the flare will cease to set the radiation angle and the mouth will act more like a diffraction slot or pinhole, so the pattern will widen. The point where this occurs is determined by the size of the mouth. But for the most part, the wall angle sets the dispersion pattern.
Previous Topic: 4 PI Theater Plans
Next Topic: Pi 2 Towers: How Careful Do I Have to Be?
Current Time: Wed Oct 21 07:43:59 CDT 2026
