Home » Sponsored » Pi Speakers » What is the bolt size and length for mounting the PSD-2002 to the H-290?
What is the bolt size and length for mounting the PSD-2002 to the H-290? [message #45003] Mon, 19 July 2004 09:16 Go to next message
James W. Johnson is currently offline  James W. Johnson
Yes I read the spec sheet but I cannot decipher what it says , I see M6 and 2.5" ..but that cannot be right.
Re: Also while on the subject. [message #45004 is a reply to message #45003] Mon, 19 July 2004 09:19 Go to previous messageGo to next message
Should I put anything else between the 2002 and H290? I noticed one of my horns does not lay perfectly flat, although it could cinch up when I bolt it on.
Also this is odd but my H290s look different from the back and one is a black satin and the other is a flat black....they clearly came off different molds.
I ordered another ...hopfully there is not a third mold!! ha ha!
Re: What is the bolt size and length for mounting the PSD-2002 to the H-290? [message #45005 is a reply to message #45003] Mon, 19 July 2004 09:32 Go to previous messageGo to next message
James,
The 2 X 1/4-20 should be sufficient to mount the driver to horn. Quarter inch diametre bolt with 20 count thread. You're looking at a pretty short bolt, either half inch or 3/4". But there're only a dime each at Home Depot bulk bins, so you can probably afford both. Get some locking washers too.
Gar.
Re: Also while on the subject. [message #45009 is a reply to message #45004] Mon, 19 July 2004 16:24 Go to previous messageGo to next message
The PSD2002 has a cardboard gasket. It will seal up nicely to the H290 when you bolt 'em together.
Re: What is the bolt size and length for mounting the PSD-2002 to the H-290? [message #45010 is a reply to message #45003] Mon, 19 July 2004 16:26 Go to previous messageGo to next message
The opposed pair of bolt holes are 1/4"-20's and 3/4" long works nicely. The three-hole mounts have M6 threads.
Re: What is the bolt size and length for mounting the PSD-2002 to the H-290? [message #45014 is a reply to message #45010] Tue, 20 July 2004 08:34 Go to previous messageGo to next message
So 3 6mm x 18-22mm would work ok?
thanks
Re: What is the bolt size and length for mounting the PSD-2002 to the H-290? [message #45016 is a reply to message #45014] Tue, 20 July 2004 11:47 Go to previous message
6mm x 18-22mm would work, yes. But the fastener head is close to the horn bell and harder to work with. Most complain about the near proximity when using these mounting holes.
Previous Topic: Crap bought a bunch of worthless crossover parts
Next Topic: 4 PI Theater Plans
Current Time: Tue Oct 20 23:38:08 CDT 2026
