Home » Sponsored » Pi Speakers » the problem is tougher than I thought!!
Re: Which 416s do you have? [message #44946 is a reply to message #44945] Mon, 12 July 2004 23:15 Go to previous messageGo to previous message
The As have all those little triangles - I remember that now.
You might think about this - though Wayne hates it. Turn the speaker around - make the back the front. cut the hole to the inside diameter of the basket rim, maybe a bit smaller (a bit, like a 1/16" on the radius).
Put some scabs around the opening of the box that would have received the front, and plan to screw the back onto the scabs to make it removable. Now you can access the driver after installation.
You can still mount your port to the now-removable back - it really doesn't matter much where the port opening is unless you plan to flush them back against a wall.
Previous Topic: The Kits
Next Topic: Looking for veneer tips for my Pis
Current Time: Fri Nov 27 05:07:41 CST 2026
