Home » Sponsored » Pi Speakers » Displacement by Horn and Driver?
Displacement by Horn and Driver? [message #44823] Fri, 25 June 2004 14:00 Go to next message
Hi Wayne,
Wondering if you've done any rough calculations in terms of how much volume is displaced by the midrange horn and Alpha10 driver.
For example, if I insert the horn and driver into a 6 cubic ft box, how much volume would I be left with?
BTW, I noticed that you specify 5.5 ft^3 for the 8PI. Is there a reason why you increased the volume by a square foot over the 2PI Towers?
thanks,
Gar.
Re: Displacement by Horn and Driver? [message #44824 is a reply to message #44823] Fri, 25 June 2004 14:49 Go to previous messageGo to next message
There's a handy little program called "volume.exe" in the PiAlign distibution file that calculates volumes of various primitive shapes. You can approximate an object using a construction of solid primitive shapes. For example, a loudspeaker cone might be approximated using a cone for the basket and a cylinder for the magnet.
Re: Displacement by Horn and Driver? [message #44825 is a reply to message #44824] Fri, 25 June 2004 17:15 Go to previous messageGo to next message
Wayne, does the 5.5 ft^3 you specified for the 8PI include or exclude the volume displaced by the horn and driver?
Re: Displacement by Horn and Driver? [message #44827 is a reply to message #44825] Sat, 26 June 2004 00:39 Go to previous message
Hi Gar,
The volume displaced by the midhorn and driver is subtracted from inner volume. I used the CSG technique I described earlier for calculating offsets.
Wayne
Previous Topic: eight π plans
Next Topic: Curious about Chip Amps?
Current Time: Sat Oct 24 09:46:18 CDT 2026
