Home » Sponsored » Pi Speakers » Typical Room Gain?
Typical Room Gain? [message #44744] Fri, 11 June 2004 14:18 Go to next message
Wondering what's typical for room gain in a quarter or eighth space configuration for lower bass frequencies. I'm doing some modelling and want to take room gain into consideration. There was a mention in diysubwoofers.org that alignments that are flat below 30hz will sound boomy in a room and that a 1dB at 30hz and 9dB at 20hz room gain should be worked into the alignment model.
thanks,
gcl.
Re: Typical Room Gain? [message #44746 is a reply to message #44744] Fri, 11 June 2004 18:18 Go to previous message
That's exactly right, and is why I prefer a slightly overdamped alignment. The response generated is the conjugate of room gain.
  • Boundary conditions and room interactions
  • Previous Topic: Thermionic 3Pi with midrange horn ?
    Next Topic: Why Front Gaskets?
    Current Time: Sat Nov 14 16:43:17 CST 2026
