Home » Sponsored » Pi Speakers » Theater 4 Plans
Theater 4 Plans [message #44695] Tue, 01 June 2004 21:15 Go to next message
TDB is currently offline  TDB
Wayne,
I am interested in building speakers for my 17 watt PP amp. Could you please send me Theater 4 plans. Do you recommend any other of your kits for my amp? I listen to all types of music.
Many Thanks -
You've got mail! [message #44697 is a reply to message #44695] Wed, 02 June 2004 10:38 Go to previous messageGo to next message
There are a few others that would work well, but the Theater four π speaker is definitely one of the best. I think you'll find it a very nice match for your 17 watt amp.
Re: You've got mail! [message #44699 is a reply to message #44697] Wed, 02 June 2004 19:22 Go to previous messageGo to next message
Wayne,
I am thinking the Theater 4's might be too big for my wife and my room. What are the next best options in a smaller box? Is there a big difference in sound between the Theater and the Thermonic series?
Thanks!!
tdb
Re: You've got mail! [message #44700 is a reply to message #44699] Wed, 02 June 2004 21:34 Go to previous messageGo to next message
You might consider the new Thermionic eight π speaker, which has a retro look that's really cool. You can also check out the Theater three π speaker, which would work very nicely with your amp. Studio one π and two π speakers are small, and the Tower two π is in-between, with a small footprint that might be a good fit for you.
  • Thermionic eight π
  • Re: So they're the size of a washer and dryer, so what? [message #44707 is a reply to message #44699] Thu, 03 June 2004 17:02 Go to previous messageGo to next message
    I'll bet if she heard them all her cares would vanish!
    Wish I could hear my 4Pi's for the first time again.
    Re: So they're the size of a washer and dryer, so what? [message #44708 is a reply to message #44707] Thu, 03 June 2004 19:20 Go to previous messageGo to next message
    No doubt she could not move them out if I moved them in. You did a fantastic job on your 4's. Could you provide me with a few details on the grills. I need to keep the little ones away from the driver.
    Todd
    Re: You've got mail! [message #44710 is a reply to message #44699] Thu, 03 June 2004 21:50 Go to previous messageGo to next message
    Give a look at the dimensions for the 4pi Stage cabinet. Very nice speaker and managable size.
    Re: You've got mail! [message #44713 is a reply to message #44710] Fri, 04 June 2004 00:06 Go to previous messageGo to next message
    Oh, that's true Bill, thanks. Good catch. The Professional Series four π speaker is nice too, and uses the same size cabinet.
    Re: You've got mail! [message #44715 is a reply to message #44713] Fri, 04 June 2004 15:32 Go to previous messageGo to next message
    The Stage 4 looks like a winner. No problems with my EL84 based tube amp? How does the degree of difficulty of the box construction compare with other models. I built my amp and preamp from scratch - this will be my first adventure into speaker building. Can you please send my the Stage 4 plans.
    Again - Many Thanks!
    Re: You've got mail! [message #44716 is a reply to message #44715] Fri, 04 June 2004 16:13 Go to previous message
    Check your mail - I've sent the plans. The Stage four π isn't what I'd suggest for some low-power SET amps, but it usually does pretty well on powerful P-P jobs. It sounds great on a Paramour 2A3 parafeed SET amp too.
    Previous Topic: Two Pi Plans
    Next Topic: 8 Pi speakers
    Current Time: Fri Nov 13 09:14:40 CST 2026
