Home » Sponsored » Pi Speakers » Question fo Wayne: 8uF cap in Theater 4 tweeter crossover
Question fo Wayne: 8uF cap in Theater 4 tweeter crossover [message #44668] Tue, 25 May 2004 11:38 Go to next message
Garland garland is currently offline  Garland garland
What change can I expect if I use a 9uF cap instead of the spec'ed 8uF?
Thanks!
Garland
Re: Question fo Wayne: 8uF cap in Theater 4 tweeter crossover [message #44669 is a reply to message #44668] Tue, 25 May 2004 12:25 Go to previous message
That's close enough. You won't notice any change at all. If you want an easy test, put a 1uF capacitor in parallel across the 8uF and it will form 9uF. Give it a listen and see if you can hear the difference. You'll hear a little click when you switch the cap in and out of circuit, or maybe some connection noise if you do it with aligator clips or something. But once the cap is in or out, the difference is teeny-tiny.
Previous Topic: studio 2 ports
Next Topic: Nice Pi Web Site Update
Current Time: Thu Nov 05 22:16:59 CST 2026
