Home » Sponsored » Pi Speakers » Pi 10 plans
Pi 10 plans [message #44611] Thu, 13 May 2004 13:54 Go to next message
smccull@mindspring.com is currently offline  smccull@mindspring.com
I'm wondering how I can get a set of plans for the Pi 10s. Anyone know? My email is smccull@mindspring.com
You've got mail! [message #44612 is a reply to message #44611] Thu, 13 May 2004 16:01 Go to previous messageGo to next message
Re: Pi 10 plans [message #44618 is a reply to message #44611] Fri, 14 May 2004 10:23 Go to previous messageGo to next message
Thanks Wayne.
Let me tell you what I'm working on and maybe you can give me some suggestions.
I'm breaking into front loaded horns with a pair of Oris 150's with Lowther DX3's. I'd like to run just a passive x-over for the high pass on the bass bins. In order to do this, what driver for the Pi 10's would you recommend? Any other mods I should think of?
Steve
Re: Pi 10 plans [message #44619 is a reply to message #44618] Fri, 14 May 2004 16:32 Go to previous messageGo to next message
The ten π cabinet is normally loaded with a JBL 2226 woofer. You can also use one of the older models, like the 2205. I'd also like to suggest you consider using the seven π cornerhorn for this application.
Re: Pi 10 plans [message #44620 is a reply to message #44619] Fri, 14 May 2004 19:18 Go to previous messageGo to next message
Kim Schultz is currently offline  Kim Schultz
Hi Wayne.
How high does the Pi7 go ?
Can you send me the plans for bith Pi7 and Pi10, please
Just replace ADD and DOT in my email.
Thx
Kim
Re: Pi 10 plans [message #44621 is a reply to message #44620] Fri, 14 May 2004 19:19 Go to previous messageGo to next message
kim"ADD"laps"DOT"dk
You've got mail! [message #44622 is a reply to message #44621] Sat, 15 May 2004 01:09 Go to previous message
Previous Topic: studio 2 towers
Next Topic: bizzaro
Current Time: Fri Nov 06 00:26:27 CST 2026
