Home » Sponsored » Pi Speakers » Peavey 10" Scorpions
Peavey 10" Scorpions [message #44608] Thu, 13 May 2004 07:51 Go to next message
Larry Acklin is currently offline  Larry Acklin
Does any one have the t/s parameters for the Peavey Scorpion 10" driver? I'd like to try some in the midhorn project (have 4) but are they close enough to the Delta (or is it alpha now) 10" to sound reasonable? Maybe just build a horn and try it out....
Larry
Re: Peavey 10" Scorpions [message #44609 is a reply to message #44608] Thu, 13 May 2004 08:26 Go to previous messageGo to next message
Sounds like a great thing to do especially if you can measure the frequency response curve. Most 'tweaking' is done this way anyway, measured and then modified, even when parameters are known.
Re: Peavey 10" Scorpions [message #44610 is a reply to message #44608] Thu, 13 May 2004 12:17 Go to previous message
The midhorn was designed to use the JBL 2012 or Eminence Delta 10. The Alpha 10 is used in the eight π loudspeaker, which has a midhorn and a large vented rear chamber. I agree with Adrian, give your Peavey's a try. The Alpha 10 wasn't the originally intended driver either, but they work very well indeed.
Previous Topic: mid range horn for the pi 4?
Next Topic: studio 2 towers
Current Time: Sat Mar 14 05:48:14 CDT 2026
