Home » Sponsored » Pi Speakers » 8pi cabinet questions
8pi cabinet questions [message #44598] Mon, 10 May 2004 08:13 Go to next message
Duncan McBride is currently offline  Duncan McBride
From the 8pi sketch it looks like the port (or ports) can be located at the bottom of the front panel, which would look really cool. If I were to use the three oval ports you put in the sketch, how big should they be? Would they be like the 2pi tower and just be the width of the cabinet side, or will I need extensions? Also, should I install fiberglass for damping in the cabinet as with other bass reflex enclosures? Foam insulation around the back of the horn?
Many thanks,
Duncan
Re: 8pi cabinet port sizes [message #44601 is a reply to message #44598] Mon, 10 May 2004 10:46 Go to previous message
If your front baffle is 5/8", then you want port area of 15.9in2. I'd go with three slots 1 1/2" x 3 1/2".
If the baffle is 3/4" then make port area 16.8in2. Use 1 5/8" x 3 1/2" slots.
If 1" baffle, then port should be 17.7in2. Make the slots 1 5/8" x 3 5/8".
Previous Topic: studio 2 tower
Next Topic: Pi vs Super Sound Boomers
Current Time: Mon Oct 26 10:31:05 CDT 2026
