Home » Sponsored » Pi Speakers » Bracing for studio 2
Bracing for studio 2 [message #44467] Fri, 23 April 2004 12:31 Go to next message
Tom Flahavan is currently offline  Tom Flahavan
I do not understand. Can anyone help?
Re: Bracing for studio 2 [message #44468 is a reply to message #44467] Fri, 23 April 2004 13:04 Go to previous messageGo to next message
I dont use any bracing in the Studio model. The cabinet is not large enough to require any.
Bill
Re: Ditto- but confirming.... [message #44469 is a reply to message #44468] Fri, 23 April 2004 13:37 Go to previous messageGo to next message
the original poster is asking about the regular 2 Pi Studio, not the tower version, which I think does use bracing.
Re: Bracing for studio 2 [message #44470 is a reply to message #44467] Fri, 23 April 2004 13:45 Go to previous messageGo to next message
The Studio Series two π Speakers don't have braces inside, but the two π towers do.
I recommended bracing each panel every 18" with a 1x2 that ties opposing panels together and lightly preloads them. Most people cross-brace the front and back with two braces, high and low in the cabinet. Cross-brace side to side in the same fashion.
Another common way to brace is to use a square section that spans the entire cross-section, but with large holes drilled in it. There are lots of good ways to brace your cabinets, just make sure that the end result is long panels are rigid enough that they sound like solid wood when rapped with your knuckle.
You might do a search here for "brace" and see what you come up with. Several people have shown photos of their cabinet's internal bracing.
Re: Absolutely [message #44473 is a reply to message #44469] Fri, 23 April 2004 19:43 Go to previous messageGo to next message
The tower is actually pretty large and I always use braces in the tower versions.
Re:These pix might help [message #44482 is a reply to message #44467] Sat, 24 April 2004 13:53 Go to previous messageGo to next message
This sorta 2Pi is the same size as the real deal and I did use a brace.
It's so easy when you have the top and bottom panels fit inside the sides, front and back. Depending on the height of the cabinet you can cut as many extra top and bottom-sized panels as you need, jigsaw a great big cut-out,and glue them up right along with the top and bottom. They also help to square the cabinet as you assemble:
Re: Bracing for Studio 2 Towers [message #44495 is a reply to message #44467] Mon, 26 April 2004 04:18 Go to previous message
Tom,
Some pictures of the Studio 2 Towers I'm building, which include pictures of the bracing, are at the link. The braces are identical in size to the tops and bottoms of the cabinets, so I cut them all at the same time. I then drill four holes in the corners of each brace and cut out the interior with a jigsaw. The resulting "frame" slides right in. The gluing gets a little sloppy, but it doesn't matter.
There are of course many other ways to do it. Each person develops and uses his own preferred techniques.
Previous Topic: JBL drivers
Next Topic: Price of kit for one speaker, or for pair?
Current Time: Sun Nov 01 13:26:52 CST 2026
