Home » Sponsored » Pi Speakers » Playing with new midrange horn.
Re: Playing with new midrange horn. [message #44458 is a reply to message #44436] Fri, 23 April 2004 05:24 Go to previous messageGo to previous message
GrantMarshall is currently offline  GrantMarshall
Hi again Wayne.
Thanks for the response.
A second way of playing with efficiency would be to play with the compression ratio if I'm following this idea right. I suspect that would be done by using a slightly larger hole in the mounting plate.
I notice that your model showed a square hole where Adrian used a round hole in front of the driver. I would expect a 4 1/2 inch square to have a lot more surface than a 4 1/2 inch circle which would affect compression ratios.
Still playing.
Grant.
Previous Topic: studio 2 towers
Next Topic: Studio PI Plans, Calling Wayne
Current Time: Sun Nov 01 07:05:45 CST 2026
