Home » Sponsored » Pi Speakers » Cornerhorns without Cornerhorns.
Cornerhorns without Cornerhorns. [message #44445] Thu, 22 April 2004 13:10 Go to next message
Can I get the cornerhorn effect of the 6-PI and 7-PI speakers without building the cornerhorn cabinet? But instead, replicate the corner geometry by placing a bass reflex in a room corner?
Gar.
Re: Cornerhorns without Cornerhorns. [message #44446 is a reply to message #44445] Thu, 22 April 2004 14:07 Go to previous messageGo to next message
Wayne can probably anser it better, but I don't see why not. The only thing that may suffer is your mid frequencies. 400+ Hz dosen't like going around corners to much, so you'd need some sort of midrange and/or other smaller speaker crossed over that's pointing directly in the room to help fill in the mids+highs.
On my system I'm running 1 old Cerwin-Vega 317P Hardrocker, which is a 15" reflex loaded enclosure, but the port fires out the back into the corner, on top of that I'm bi-amping to a an old pair of Marantz 10" 3-way's. Everything balances out pretty good, it's somewhat hard to tell where the lows are coming from because of the corner loading and the 100Hz/12db octave x-over on them.
So turn one of your speakers in the corner give it a listen see what you think. That's half the fun of doing this hobbie, experimenting.
HTH
Bill W.
Re: Cornerhorns without Cornerhorns. [message #44448 is a reply to message #44445] Thu, 22 April 2004 16:24 Go to previous message
Yes, you sure can.
Previous Topic: A few questions from a non DIY guy.
Next Topic: studio 2 towers
Current Time: Sun Nov 01 04:00:12 CST 2026
