Home » Sponsored » Pi Speakers » Theater seven pi corner horn
Theater seven pi corner horn [message #44193] Fri, 19 March 2004 07:59 Go to next message
CSHalle is currently offline  CSHalle
Hi,
I was wondering if the Theater seven pi corner horns would be a good option for me. I listen mostly to classical music (Mahler, Strauss, Schoenberg, etc.) and acoustic jazz. My dedicated listening room is only 204 square feet (17' X 12' X 7') - the room being located in the basement. I currently own a SS amp (Cambridge A500), but I'm planning to buy a pair of Paramour. I'm also dreaming of getting a pair of Edgar or Martinelli's wood horn. What do you think ?
Thank you,
CS Halle
Re: Theater seven pi corner horn [message #44195 is a reply to message #44193] Fri, 19 March 2004 11:10 Go to previous messageGo to next message
Naturally I'm biased but I think you'll be very pleased. Many people use the Martinelli horns on top. I've also got a midrange horn that I'll be offering very soon and you can easily incorporate it into the design by putting it on top too. No crossover needed on this mid horn, so you can just drop the crossover frequency of the woofer down so it's easy to add on to an existing pair of π horns or cornerhorns. More to come in just a few days.
Thank you ! (nt) [message #44196 is a reply to message #44195] Fri, 19 March 2004 14:28 Go to previous messageGo to next message
Re: Theater seven pi corner horn [message #44197 is a reply to message #44195] Fri, 19 March 2004 17:25 Go to previous messageGo to next message
Hey Wayne
Surely there must be a highpass filter to prevent frequencies below cutoff from entering the horn and using up all the excursion? Like a subsonic filter.
Adrian
Midrange horn [message #44210 is a reply to message #44197] Sat, 20 March 2004 20:52 Go to previous message
You could sure employ a high-pass filter to good effect, and especially when used in high-power sound reinforcement applications. But the horn is designed to use 10" drivers that handle several hundred watts and you can push 'em pretty low. So the upper and lower rolloff slopes can be used as crossover points instead.
In fact, I had initially started this project with the JBL 2012 and Delta 10 drivers in mind, and that is still what the horn is primarily for. But it occured to me during testing that it might be worth checking an Alpha 10 in one too. The rear chamber can be made into a vented system similar to a mini A7 and the horn would probably make a neat little two-way when paired with a compression horn. The horn itself doesn't provide much output below 100Hz, but the vented rear chamber would, so an Alpha 10 in these horns might make a fun little system too.
Previous Topic: What's this 1.4" throat thing?
Next Topic: mid-range horn
Current Time: Thu Oct 15 23:08:34 CDT 2026
