Home » Sponsored » Pi Speakers » Passive Line Level Compensation Network?
Re: Passive Line Level Compensation Network? [message #44111 is a reply to message #44108] Tue, 02 March 2004 16:23 Go to previous messageGo to previous message
It's a reactive network, and the only real difference is that the output level filter is designed for a low impedance load whereas the input level filter is designed for a high impedance load. As an example, a filter designed for the output circuit might use a 10µF capacitor, having reactive impedance of 8 ohms at 2kHz. With an 8 ohm speaker load, that's an appropriate value. If the preamp input impedance is the typical 47Kohms, then a similar preamp-level filter might use a 1700pF capacitor instead. But the basic filter is the same, just using different values that are appropriate for the impedance of the circuit.
Previous Topic: are Beyma Pro drivers any good for Hi-Fi? Comparable to JBL's?
Next Topic: CrossOver questions on 4 Pi
Current Time: Sun Nov 08 22:42:19 CST 2026
