Home » Sponsored » Pi Speakers » CrossOver questions on 4 Pi
CrossOver questions on 4 Pi [message #44087] Sat, 28 February 2004 18:48 Go to previous message
HaknHendrix is currently offline  HaknHendrix
After receiving the Pi crossover schematics from Wayne, and following a bunch of threads on the subject in the forum, I think I am almost there.
In consideration of using the PXB2-1K6 Eminence crossover for the 4 PI theater (Delta 15a, PSD2002), I would like to confirm and get suggestion on the following:
Tweeter Compenstion: R1, R2, and C1.
R1 and R2 would be constructed from two sets of four 30 ohm, 10 Watt resistors. This would provide a create a 16 ohm, 40 watt network. Would use PE part number: 004-30.
C1 - not much luck in tracking down a 0.47 uF, 200V (NP) capacitor - any suggestions?
Woofer Zobel configuration: C5 and R3.
R3 - requires an 8ohm resistor. Please advise as to what dummy load resistor would be appropriate, the 100 watt or the 200 watt version (019-020 or 019-030 respectively).
C5 - 20 uF - what voltage rating would be advised and what PE partnumber would be appropriate?
By the way, I will be using a 100W SS amp for the time being - does this impact the crossover componentry?
Thanks in advance!
Hakn
Previous Topic: Passive Line Level Compensation Network?
Next Topic: Audiophile Pi7 plans please
Current Time: Sun Nov 01 08:07:07 CST 2026
