Home » Sponsored » Pi Speakers » can the 2445J use in the pro 4 instead of the 2426?
can the 2445J use in the pro 4 instead of the 2426? [message #43870] Thu, 05 February 2004 10:06 Go to next message
Zeno is currently offline  Zeno
hi wayne,
i understand that the 2445J is 16 ohm, can i really use them with a 8 ohm woofer in a two way?
thanks
Re: can the 2445J use in the pro 4 instead of the 2426? [message #43871 is a reply to message #43870] Thu, 05 February 2004 11:42 Go to previous message
Certainly, the 2445 can be used, but it is a 2" exit compression driver, so it isn't a direct replacement for the 2426. You'll need a different horn flare, but it will work just fine. You'll have more crossover options since you can run the HF horn lower but it won't have quite as high frequency extension using the larger device.
About 16 ohm drivers, there is some re-work of the 8 ohm version of the crossover necessary (obviously) but it isn't nearly as much as I would have thought. Check out the post called "16 ohm vs 8 ohm drivers"
Previous Topic: I have a 2500 LP collection for trade/sale
Next Topic: BMS compression drivers and Pi ?
Current Time: Thu Nov 05 22:23:51 CST 2026
