Home » Sponsored » Pi Speakers » PiAlign program
Re: PiAlign program [message #43778 is a reply to message #43755] Tue, 27 January 2004 06:01 Go to previous messageGo to previous message
David Morrison is currently offline  David Morrison
i think i understand how the horn and vented box work together now. The vented enclosure is tuned low and the cut off of the horn is a little higher. using the peaks from the event and the horn creates a bandpass type of response that is flat broad and effecient.
If the horn cutt off is lower or the vented box is tuned higher than peak in the responce is created.
my next question if this is right how can you predict a peak in the box. say if the box is only going to be use for below fifty hzs. and you want more of peak below that use a larger horn bigger box ?
Previous Topic: One PI Port Size
Next Topic: Found a new source for driver parameters
Current Time: Fri Nov 06 01:18:30 CST 2026
