Home » Sponsored » Pi Speakers » What are compensation networks?
What are compensation networks? [message #43767] Mon, 26 January 2004 14:17 Go to next message
la malta is currently offline  la malta
Hi,
I'd like to try buiding my own pro audio 2 way. I've read that using larger 12" and 15" woofers requires a compensation network.
What is a compensation network and what does it do?
Thanks.
Re: What are compensation networks? [message #43772 is a reply to message #43767] Mon, 26 January 2004 19:52 Go to previous messageGo to next message
Compensation networks are electronic EQ and/or impedance compensation devices. An example is a Zobel circuit, which is used to remove a response peak that would otherwise result from the interaction of capacitance in a passive crossover and the speaker's voice coil. Another example is horn compensation.
See the response curve of the tweeter circuit of a π Speaker using a compression horn:
Response curve for HF circuit of π Crossover
For more information, see the links on the post called "A few useful documents."
Re: What are compensation networks? [message #43774 is a reply to message #43772] Mon, 26 January 2004 21:58 Go to previous message
Thanks!
Previous Topic: same speakers
Next Topic: Constrained spatial loading
Current Time: Wed Oct 21 11:05:29 CDT 2026
