Home » Sponsored » Pi Speakers » Can someone recommend a 15" for subwoofer?
Re: Can someone recommend a 15" for subwoofer? [message #43654 is a reply to message #43649] Wed, 14 January 2004 09:27 Go to previous messageGo to previous message
Aside from the cabinet and power amp, can you describe any other
characteristics you are concerned with? I'm at least familiar with
the Karlsons, and from the web site there are several drivers
recommended. By digging up the T/S specs for those, you can search
for current drivers that are close. You can also model the drivers
listed, find a standard tuned box they'd use, then search for a current
driver that has similar characteristics. Wayne uses several differet
Eminence models as well as the professional JBL's. Try those
compared to the listed drivers.
Chris
Previous Topic: Montreal Pi
Next Topic: UHF driver selection suggestions and thoughts?
Current Time: Thu Nov 12 11:39:18 CST 2026
