Home » Sponsored » Pi Speakers » request pi seven cornerhorn plans
Thanks! some questions... [message #43599 is a reply to message #43598] Thu, 08 January 2004 13:08 Go to previous messageGo to previous message
artsybrute is currently offline  artsybrute
Thanks Wayne. They came through fine.
Question: You show a vent that's 3-1/4" deep and your plans specify 3/4" plywood.
I know it will end up weighing a ton, but I'm using 1" mdf. So
1. Are the vent length and width dimensions inside or outside?
2. Should I shorten up the depth of the vent by 1/4"?
3. Should I move the vent location 1/4" away from the side and bottom?
4. I maintained inside dimensions for the overall width,length and height of the speaker, adding 1/2" to each overall. Is this correct?
Thanks again!
Previous Topic: New address, same format
Next Topic: Final Pix Premium Stage 4 Pi in Theatre 4 Pi
Current Time: Fri Nov 13 08:35:36 CST 2026
