Home » Sponsored » Pi Speakers » Cabinet question ?
Re: Cabinet question ? [message #43565 is a reply to message #43563] Sun, 04 January 2004 19:03 Go to previous message
Post this one over in the Craftsmen forum, so you'll get more replies. I think you'll get some here and some there, so that will increase the amount of input you get.
I'm not a cabinetmaker, but I've been around and seen a few built. Seems like they always veneer last, after the holes are already cut. the veneer is trimed along the edge with a sharp blade, such as a razor blade or utility knife.
I suppose there is no harm veneering the box before cutting the mounting holes as long as the cutting tools are very sharp and make a good clean cut. But all the cabinetmakers I've ever known finish the cabinet first, and then veneer, trimming the edges with a very sharp blade.
Previous Topic: JBL 2220 Corner Horn
Next Topic: 2 pi tower port diameter?
Current Time: Sat Oct 24 10:54:45 CDT 2026
