Home » Sponsored » Pi Speakers » T-nut spinning in place - what to do?
Re: T-nut spinning in place - what to do? [message #43494 is a reply to message #43492] Sun, 28 December 2003 21:05 Go to previous messageGo to previous message
Perhaps you can pull the T-Nut to drive it into the wood. Here's a possible solution:
Get a very long screw with the same threads and replace the one you have in there now. Then, rather than drive the screw all the way down, simply use it as a sort of handle to pull the T-Nut into the wood. Once you've pulled it into the wood a little bit, reinsert your standard screw and tighten it down.
Just a thought.
Previous Topic: 6 Pi plans
Next Topic: Pi 2 photos
Current Time: Sun Nov 01 17:55:51 CST 2026
