| Re: Yes - related to the horn thread above [message #43414 is a reply to message #43396] |
Fri, 19 December 2003 06:26   |
wunhuanglo
Messages: 912 Registered: May 2009
Illuminati (2nd Degree) |
"Modern" bass drivers really bother me in that the flange area seems just preposterously narrow. As a mechanical engineer I haven’t been know for my elegant, minmalist "Japanese car parts" design - I’m more of a ham-fisted, more-is-better kind of guy. I like the Altec 16" rim on the 15" driver. Plenty of surface area for tee nuts and the like. But the narrow rim drivers just don’t seem to leave much mounting surface. Am I just nuts here?
| They are for my Karlson cabinets [message #43418 is a reply to message #43396] |
Fri, 19 December 2003 10:55   |
drguayo
Messages: 84 Registered: May 2009
Viscount |
In Reply to: Yes posted by Wayne Parham on December 16, 2003 at 16:21:31: I bought the Karlson cab's from Replay George. The 15" Kilomax's it had are going in my Bill E's cabinets so I was thinking what 15" Eminence would be best in this cab - and may try the 15" Beta coax. Wayne - maybe you're familiar with the Karlson cab and know which driver is best? thanks craig.
| Re: They are for my Karlson cabinets [message #43419 is a reply to message #43418] |
Fri, 19 December 2003 17:16  |
You could use the Eminence Omega 15 with good results, but I don't think I'd use the Beta 15. In fact, I don't think you'll find acceptable performance when substituting any of the pressed-frame Eminence 15" models, because the cabinet size will probably be wrong.The Eminence Beta 15 is tuned quite differently than a Kilomax 15, needing a much larger box. The Kilomax 15 performs well in relatively small cabinets between about 3ft3 and 8ft3 but the Beta 15 needs a much larger box. The Beta 15 should be used in cabinets no smaller than 5ft3, and would work well in boxes as large as 30ft3. If your cabinet is between 5ft3 and 8ft3 or so, you can probably do the swap, although you'll most likely need to change the port.
