Home » Sponsored » Pi Speakers » Update
Update [message #43381] Mon, 15 December 2003 19:10 Go to previous message
Was thinking about reflections screwing up my measurement graphs today, the area I had been testing in did not have any walls or fences etc around the front or back of the horn, however there was a wall and a fence pretty near on each side. I flipped the horn the other way to do the measurements to reduce reflections off these surfaces (by reducing the horizontal dispersion by flipping it). However today I thought to myself to go out and get some cable instead. I had to buy 20 meters of speaker cable and another 20 meters of RCA cable so I could do the measurements way out where theres no surrounding fences, walls, or anything else.
The results I got changed for the better! I have two response graphs here, one is of the first conical horn I built which had a small throat of 27cm^2, and the second graph is of the second conical horn I built with 50cm^2 throat. Other than throat size differences both horns were the same length, mouth area, etc.
Horn with 27cm^2 throat, ~1.5L back chamber with lining
And here is the horn with larger throat, 50cm^2 with ~1.5L back chamber with lining.
Concerning ~500Hz to 1.6KHz usage, which one would you say is more smooth/less amplitude deviation? I think that the one with large throat is better for a higher xover point say 2KHz (pretty obvious), however regarding the peaks/dips and shelves at the low end, am not sure which one to choose. Any comments/guidance on which graph is "better" is much appreciated.
Adrian
Previous Topic: Theater 4 cutout problem
Next Topic: Why the move???
Current Time: Sun Nov 01 16:34:50 CST 2026
