Home » Sponsored » Pi Speakers » crossover help
crossover help [message #43334] Thu, 11 December 2003 10:11 Go to next message
gazzamongo is currently offline  gazzamongo
i've got altec 806/811's and am trying to piece a system together...i got a behringer cx3400 crossover which hisses like a cheap fm tuner between stations and generally sounds nasty so i'm thinking about going passive instead
my altecs will sit atop a karlson 15 with klipsch k33e-s (not built yet)
would anyone be willing to share their crossover circuit design or point me to some resources on this subject as i have little knowledge of crossover design and could use the help
cheers
Gary McDonnell-Thomas
p.s did find this site....would a crossover like the one above do the trick
Re: crossover help [message #43336 is a reply to message #43334] Thu, 11 December 2003 11:34 Go to previous messageGo to next message
When using an Altec horn atop a direct radiator, you'll want some padding of the horns. The attenuator will serve double-duty as the damper circuit and can provide top-octave compensation as well. I'd put a standard Zobel on the midwoofer. Other than that, the second-order network you've described will work just fine if you cross-connect the tweeter, wiring "+" to "-". The tweeter motor and the woofer motor should be aligned vertically, within four inches front to back. That gives you a pretty wide position tolerance window where performance will be good.
thanks but whats a zobel [message #43338 is a reply to message #43336] Thu, 11 December 2003 12:38 Go to previous messageGo to next message
thanks for quick reply...
i am reading through some earlier posts on crossover ..spice "101" etc...but haven't seen a desription of a zobel yet
care to enlighten me
thanks in advance
btw are any of the pricier dsp crossovers any good
Re: thanks but whats a zobel [message #43339 is a reply to message #43338] Thu, 11 December 2003 13:08 Go to previous messageGo to next message
Hi Gary,
loudspeakers101.com helped me a lot in understanding crossovers. It's also a great online too for calculations too.
gar.
Zobel dampers [message #43340 is a reply to message #43338] Thu, 11 December 2003 13:23 Go to previous messageGo to next message
Check the π Crossover Document for a description of Zobel dampers. You'll find them on page 37 and then again on pages 48-52, where Zobel's on woofers with second-order filters are shown.
The short version is that a Zobel circuit for a voice-coil driver loudspeaker is an RC damper that is formed with a capacitor and resistor connected in series. The values for each component can be calculated using the formulas on page 37 of the π Crossover Document. The damper is connected directly across the woofer, and it removes a resonant peak that will form due to the interaction between the speaker's voice coil and crossover components. You can see an example of this peak on page 47 of the crossover document. Subsequent pages show the improved response curve resulting from inclusion of the damper in the circuit.
much obliged, ...(nt) [message #43341 is a reply to message #43334] Thu, 11 December 2003 14:18 Go to previous messageGo to next message
Re:Hey Gazzamongo, " Getting there is half the fun" [message #43344 is a reply to message #43334] Fri, 12 December 2003 04:19 Go to previous messageGo to next message
I had you come over here instead of just posting my x-over so you'd meet Wayne. My level of knowledge is best reflected in the referenced post.
But for what it's worth the attenuation circuit I put on the "+" side of the horn is 32 ohm R and .33uF C, with 16 ohms shunt across the "+", "-", ahead of L1. Don't know the sensitivity of the K33 so you'll have to play with the resistance.
Live, Nude Resistors
Creating is more like performing than listening
glad i stopped by [message #43361 is a reply to message #43344] Sat, 13 December 2003 07:01 Go to previous message
wayne is clearly a treasure trove of useful information as are all the other helpful people on these boards
cheers
Previous Topic: In-wall speaker kits/plans
Next Topic: All JBLPRO and Altec Home Theatre (almost) Hubba-Hubba!
Current Time: Mon Nov 02 03:52:31 CST 2026
