Home » Sponsored » Pi Speakers » Guys, help me design a smokin' midrange horn...
Re: You could try this design [message #43283 is a reply to message #43281] Sun, 07 December 2003 09:12 Go to previous messageGo to previous message
Thanks Adrian, great work!!! :)
What's the rear chamber volume on this setup?
I'm pretty impressed with that horn performance, so I think I'm going to give it a try. It's a simple conical horn, so it won't be a lot of work to build a test unit anyway.
Does your design use a rear chamber volume of any kind? If so, what should the volume of the enclosure be?
Thanks again.
Adam
Previous Topic: Why the move???
Next Topic: Do all 15 Eminence drivers have same mount pattern?
Current Time: Sun Nov 01 19:05:21 CST 2026
