Home » Sponsored » Pi Speakers » Guys, help me design a smokin' midrange horn...
Guys, help me design a smokin' midrange horn... [message #43276] Sat, 06 December 2003 15:41 Go to previous message
The guys at work are getting all down about horns and how they are just loud and can't sound good. I want to show them how wrong they are! I could show them with my Eminence 2-ways, but I'd like to go the full monty and show them with a midrange horn as well.
The base platform is the Seas Excel W18EX. If you guys arent' familiar with this driver, it's is wildely considered one of the best midrange drivers in the world. They are less renouned for midbass performance, but I've foudn they sound increidble in that area as well, in the right box. I have four spare ones right now, waiting for a use.
My goals are wide band operation and flat frequency response over effeciency. I'd like something that will do around 200 Hz to 1.5 kHz, to couple with a PSD-2002 for the top end. a 1/8th space, 1/4 wavelength horn should be fine. If 1/2 wavelength will greatly improve things, I'll do it though.
I'd like to do a traxic or an exponential. I also have Sound Easy, so I can measure and tweak the final results. It has horn design implimented, I'm just not comfortable with it yet.
I've done a fair bit of helping on this board I think, so I'm cashing in a favour ;) I need a really wicked design. I'll have the measurement capabilities to fine tune.
T/S specs for the Excel:
RE = 6.1 ohms
LE = 0.4 mH
FS = 31 Hz
SD = 125 sqcm
VAS = 37 litres (1.3 cuft)
QMS = 2.00
QES = 0.27
QTS = 0.24
Here is the data sheet
http://www.seas.no/excel_line/excel/E0017.PDF
You can consider response between 1 kHz and 100 Hz flat, even though it steps down. The reduction is caused by baffle step.
Thanks guys, I'd really apprecaite something!!!!
Adam
Previous Topic: Why the move???
Next Topic: Do all 15 Eminence drivers have same mount pattern?
Current Time: Sun Nov 01 16:44:58 CST 2026
