Home » Sponsored » Pi Speakers » Adam, how big are your Kappa boxes?
Adam, how big are your Kappa boxes? [message #43262] Thu, 04 December 2003 10:40 Go to next message
Hi Adam,
I have a couple of Kappa15A's I'm going to build someday and
was wondering if you use those drivers or the LF versions?
Also, what size box are you using? The Kappa's don't go real
low in a Pi sized box. I'm looking at a 6 cu. ft. box tuned
to 40Hz for about 45Hz 3db point.
Thx, Chris
Re: Adam, how big are your Kappa boxes? [message #43265 is a reply to message #43262] Thu, 04 December 2003 17:53 Go to previous message
My Kappa 15LF's are running in 5 cuft boxes tuned to something like 37 Hz. I made them like two years ago so the memory is a bit fuzzy, they're also sold now.
The bottom end is quite solid on them. It leaves *just* a bit to be desired, but they are quite smooth and go quite deep. I've played some movies on them and they handle the low rumble surprisingly well.
Adam
Previous Topic: 2Pi Tower Update: APT80 Tweeters
Next Topic: Need one JBL2227HPL and an box advice
Current Time: Mon Oct 26 13:46:17 CDT 2026
