Home » Sponsored » Pi Speakers » Conical Midrange horns
Conical Midrange horns [message #43209] Thu, 27 November 2003 17:29 Go to previous message
Hi everyone!
Is there anything wrong with using a conical horn for the midrange, say a range from 300Hz to 1.6KHz?
People are always reccomending Tractrix or Hyperbolic for the midrange, but never conical. Some of you might remember I built two Tractrix horns for some Alpha 6's I've got, they perform great, but I just found today in a Hornresp simulation that if I built a conical horn then the HF extension would be even higher in a horn of the same size and is still flat which is good.
Are conical horns the straight sided horn? Is the Unity horn a conical horn?
If its a straight sided conical horn, it isn't a CD horn is it, I could make wider coverage angle/dispersion in the horizontal than the vertical planes if I wanted without ruining the hornresp simulated response?
So whats the pro's/con's of a conical midrange over a tractrix midrange horn? I remember reading on this forum a few months back that conical has lower THD/phase distortion???
BTW: What does the FTA box mean in hornresp? Its for conical horn mouth flare tangent angle when I'm simulating a conical horn, what use is this? Also why doesn't the conical horn simulation show the flare frequency it is always 0.00Hz, although it doesn't affect the simulation really.
Thanks!
Adrian
Previous Topic: settle once and for all
Next Topic: Speaker Motors
Current Time: Sat Oct 24 11:52:59 CDT 2026
