Home » Sponsored » Pi Speakers » How to connct an L-pad ?
Re: How to connect an L-pad ? [message #43054 is a reply to message #43053] Sun, 16 November 2003 15:48 Go to previous messageGo to previous message
If your L-Pad is made for an 8 ohm load, then put an 8 ohm resistor across your tweeter. If the L-Pad is for 16 ohms, then put a 16 ohm resistor across the tweeter. Piezoelectric tweeters are primarily capacitive, and have fairly high impedance, so you'll need to add a shunt resistor across the tweeter to form a voltage divider for the L-Pad to work. Give that a try and see what happens.
Previous Topic: Another side of the small and cute vs. big and efficient debate:
Next Topic: 2 pi Tower - tweeter upgrade Wayne & others?
Current Time: Sun Nov 01 12:24:55 CST 2026
