Home » Sponsored » Pi Speakers » How to connct an L-pad ?
Re: How to connct an L-pad ? [message #43052 is a reply to message #43048] Sun, 16 November 2003 10:06 Go to previous message
Jeff Robinson is currently offline  Jeff Robinson
In re-reading your post I notice you make no mention of an existing crossover network. If using an amp larger than 2 watts you must use a crossover network or you will almost certainly blow your tweeter.
The cabinet + (hot) and - (ground) terminals feed power into the crossover. The crossover output then feeds "high pass filtered" signal power to the L-Pad which then feeds the tweeter.
The simplest crossover is a first order (6 dB/oct) which is just a single capacitor in series with the tweeter/L-Pad (a 4.7 μF capacitor will cross an 8 Ω tweeter about 4,200 Hz). There are higher order crossover topologies but you'll need to do some studying before attempting to design a crossover from scratch.
Jeff Robinson
Previous Topic: Another side of the small and cute vs. big and efficient debate:
Next Topic: 2 pi Tower - tweeter upgrade Wayne & others?
Current Time: Sun Nov 01 12:24:14 CST 2026
