Home » Sponsored » Pi Speakers » AC cct troubles
Re: AC cct troubles [message #43040 is a reply to message #43036] Sat, 15 November 2003 11:07 Go to previous messageGo to previous message
What I've always done was to first find all reactive impedances. Then one can find total impedance which will allow finding total current. For simple circuits having only a single resistance and reactance, there are simplified formulas; Complex networks require calculation using vectors. You can also find current through each branch, by knowing reactive impedance and voltage across the node. But as you know, the sum of all branch currents will not be equal to total current because of power factor, i.e. phase angle.
Previous Topic: paramours with 4pi
Next Topic: Horn-Loading a Delta 10
Current Time: Sun Nov 01 13:29:04 CST 2026
