Home » Sponsored » Pi Speakers » AC cct troubles
AC cct troubles [message #43034] Fri, 14 November 2003 19:42 Go to previous message
hi !
wayne-ok to post here? i thought it would be ok,and you would know to answer it too.
i was doing some revision,and used an online site for a textbook because we dont get decent ones that tell us what we need to know...
ok i was reading my notes,and i have one method that i understand,but cant tell if its a correct example,and the 2nd one,is an 'answer' to a question i did in an assignment,problem is i completely have no idea what hes doing in it.
thanks alot!
i know its simple,yet my tutor hasnt explained it well in a way i can use.
i have looked at a site but it uses different methods...(listed at bottom)
is this correct ??
(AC Parallel circuit.)
Obviously Convert mH or F into Xl/Xc Reactance
eg
5Ω
work out angle if any resistance included =
eg
ta-1= Xl/r
=-53°
Z = 5 Ω
Previous Topic: paramours with 4pi
Next Topic: Horn-Loading a Delta 10
Current Time: Sun Nov 01 11:13:27 CST 2026
