Home » Sponsored » Pi Speakers » insulation behind woofer
insulation behind woofer [message #43008] Wed, 12 November 2003 14:12 Go to next message
r. wood is currently offline  r. wood
Do I cut out the r13 fiberglass insulation behind the woofer{mounted to the baffle). I know I leave it on the back of speaker box. They are stuido two speaker kits. and Im about done with the cabnets. R. WOOD
Re: insulation behind woofer [message #43014 is a reply to message #43008] Wed, 12 November 2003 18:58 Go to previous message
Insulation is live end-dead end. Goes on the entire rear panel but not on the front. On the bottom but not on the top. On one side but not on the other.
JBLPRO also covers the cross braces.
And there you have it.
Creating is more like performing than listening
Previous Topic: KG2>PI1 or PI2 Conversion?
Next Topic: Spice
Current Time: Sun Nov 01 16:41:57 CST 2026
