| Eminence X-over for 4Pi [message #42987] |
Tue, 11 November 2003 07:01  |
Chris R
Messages: 133 Registered: May 2009
Master |
Hi Wayne, I've seen you recommend these as an economical way to get the base X-over, then add the attenuator and HF comp. I'm all hooked up with spice so I can view the effects of the attenuator on x-over freq, except that I don't have the schematics from Eminence to plug into the spice model. Is that available? Thx, Chris
| Re: Eminence X-over for 4Pi [message #42989 is a reply to message #42987] |
Tue, 11 November 2003 07:56   |
Components L1, L2, C2, C3 and C4 are on the Eminence crossover PCB, which are sourced by, and which use the same component values as the corresponding π Speakers 500Hz, 800Hz and 1.6kHz crosssovers. The 600Hz and 250Hz/1.6kHz units are also sourced by Eminence, but are special order items, available only through π Speakers.But for your application - the π 1K6a010dB crossover used in your four π's - It can be made using the Eminence PXB2-1K6 PCB, adding a compensation cable assembly for the tweeter and Zobel damper for the woofer. There are some photos of these addition cable assmblies in the post called "Compensation networks - Photos." And the Spice model for the crossover can be found in the distribution of Spice available here, on the π Speakers website.
