Home » Sponsored » Pi Speakers » Pi seven port size using Altec 421A 15" Drivers
Pi seven port size using Altec 421A 15" Drivers [message #42970] Sun, 09 November 2003 11:45 Go to next message
jumpin is currently offline  jumpin
I am building a pair of Pi Sevens using altec 421A 15" 8ohm drivers. Could someone advise on correct port lenght and dia. Any advice on bracing would also be helpful. I am using 18mm MDF.
Cheers Jumpin
Re: Pi seven port size using Altec 421A 15" Drivers [message #42971 is a reply to message #42970] Sun, 09 November 2003 14:41 Go to previous messageGo to next message
According to "Great Plains Audio," Altec specs for the 421-8H are as follows:
Vas = 12.8ft3
Fts = 32Hz
Qts = 0.25
Based on these values, PiAlign recommends a 3.2ft3 cabinet tuned to 48Hz using a port that's 7.5" long, 4.6" tall and 8.2" wide.
Response is nice and flat with 60Hz f3 and 40Hz f10.
If this isn't the driver you have, you might consult the Altec T/S Specifications chart at Great Plains Audio to obtain the specs you need.
Re: Pi seven port size using Altec 421A 15" Drivers [message #42972 is a reply to message #42970] Sun, 09 November 2003 17:53 Go to previous messageGo to next message
Hi; What hf driver will you be using if I may ask, Only because I use the 421 in an 4.2cu.ft. enclosure base reflex tiangular shape with an 811/806 on top and the stock 800 hz. xo and would be interested in your chioce of hf.
If I am not mistaken... [message #42998 is a reply to message #42972] Tue, 11 November 2003 18:36 Go to previous message
Shanko is currently offline  Shanko
..I think Jumpin is using another big round tractrix (Oris variant) loaded with PM2A's. Crossover around 140 hz. He hasn't answered because he is cutting panels for his 7Pi's!
Previous Topic: Eminence X-over for 4Pi
Next Topic: Ten Pi Plans
Current Time: Fri Nov 13 05:42:37 CST 2026
