Home » Sponsored » Pi Speakers » Epstein, Epstein....paging Mr. Epstein
Happier with 2226J's [message #42923 is a reply to message #42920] Thu, 06 November 2003 09:00 Go to previous messageGo to previous message
spkrman57
Jerrod,
If are running with tube amps, why worry about the 2226H, when the 2226J can be matched up to the amp transformer taps. I use mine on 8 ohms taps on my Norh SE-9, and on Push-Pull amps, must be more exact(read that hooked up to the 16 ohms taps). I use 902C horn driver (8 ohm) and standard Pi crossover 1.6Khz(R1=30ohm/R2=15ohm/.47 ufd cap). I have used this for 806A/802D mainly. I am using 650hz tractix horn(Edgar round wooden). With my new 902's, I am going to wire up another crossover with R1=40 ohm/R2=12.5 ohm(25 ohm X 2 parallel) and use .33 ufd cap. The 902 is more efficient than the 806's and need that slight edge taken off. If you want more details, let me know!!!
Ron
Previous Topic: JBL Woofers For Sale, Possible Trades
Next Topic: Theater 4 Pi project
Current Time: Sat Nov 28 18:09:31 CST 2026
