Home » Sponsored » Pi Speakers » Journal of a First-time Builder - Pt 1: Assembly
Port size for thicker baffles [message #42901 is a reply to message #42892] Tue, 04 November 2003 21:39 Go to previous message
Sounds like those are going to be absolutely great. Just a word about baffle thickness - Since the port length is set by panel thickness, the Helmholtz frequency is a function of the thickness of the wood. I recommend changing the port diameter so that the Helmholtz frequency is maintained if a different baffle thickness is chosen. A 4 3/4" hole cut through a 1" baffle will tune this box to the same frequency as a 4 5/8" hole cut through a 3/4" baffle or a 4 1/2" hole cut through a 5/8" baffle.
So if you haven't already cut the port hole, I'd suggest making it 4 3/4" diameter for panel thickness of 1". If you've already cut it, you may be able to enlarge it a little bit. Since the hole for a 1" baffle is slightly larger than for the thinner baffles, it probably shouldn't be too difficult to modify if a smaller hole has already been cut. It's better to have a hole too small than one too big, since enlargements can be done without patching.
Previous Topic: Field coil speaker replacement advice...
Next Topic: How to choose the correct Horn??
Current Time: Fri Oct 23 06:17:30 CDT 2026
